It is currently Sun Aug 03, 2025 4:48 pm
PostPosted: Fri Nov 09, 2018 2:13 pm
I was doing a level and setup on a twenty-year-old larrivee and measured the radius at about 16" to the 3rd 20" to the 12th and then nearly flat to the sound hole. I thought for sure it had had a refret and somebody sanded the board beforehand, but the customer told me he bought it new.
All I could find on the internet was larrivee uses a 16-20" radius. I've seen one of their old machines, and it does not look like there is much room for adjustment.
New username, same ole Pat Macaluso!
These users thanked the author Pmaj7 for the post: pkdz (Sun Nov 11, 2018 9:03 am)
PostPosted: Fri Nov 09, 2018 4:37 pm
The tongue of the FB was usually untouched on the profiler.
The goal was to have a little horseshoe pattern left of unsanded wood. The railer would hit the edges of the board all down the length on each side, but due to the curved radius, the centre of the board would be untouched. Then feather the transition with some 180 on a cork block. So yeah, to have the area right next to the soundhole be flat is totally normal.
These users thanked the author meddlingfool for the post (total 2): Michaeldc (Fri Nov 09, 2018 8:20 pm) • Pmaj7 (Fri Nov 09, 2018 6:34 pm)
PostPosted: Fri Nov 09, 2018 6:41 pm
Well that explains it! So it's actually a 16"-flat. With that process, I assum they were hammering the frets in? Anyway, I was able to get the action lower than normal on that one.
PostPosted: Fri Nov 09, 2018 8:15 pm
the compound radius goes all the way to the body join, then it turns to fallaway. Yep, hammered frets.
These users thanked the author meddlingfool for the post: Bryan Bear (Thu Nov 15, 2018 2:12 pm)
PostPosted: Fri Nov 09, 2018 8:16 pm
If I remember, I'll post a pic next time I'm at that step as I use one of their old machines...
These users thanked the author meddlingfool for the post: Pmaj7 (Sat Nov 10, 2018 1:35 am)
PostPosted: Fri Nov 09, 2018 8:42 pm
Last Name: Colbert
City: Anacortes
Pretty sweet having the authority on the forum!
Thanks!
PostPosted: Sat Nov 10, 2018 12:09 am
It was 18 years in the trenches of real life application, I value it more now than I did at some points...
PostPosted: Thu Nov 15, 2018 1:59 pm
Ed, what action did you send them out with?
PostPosted: Thu Nov 15, 2018 2:12 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Interesting, I plane in my compound radius then grind in the fallaway on the fret tops when leveling. I'm mildly annoyed at the extra time to take so much off those frets. It never occurred to me that I could plane in the fallaway. I'm gong to try to do that. I'm not 100 percent sure I can get consistent shavings with the heel of the plane riding on a slightly elevated surface.
Bryan Bear PMoMC
PostPosted: Thu Nov 15, 2018 4:22 pm
.090 bass, .070 treble, with as little relief as you can get away with. This seems to be a good generic beginning setup that pleases most people out of the gate.
These users thanked the author meddlingfool for the post: Pmaj7 (Thu Nov 15, 2018 8:14 pm)
PostPosted: Thu Nov 15, 2018 4:23 pm
Hard block + 100 grit...
PostPosted: Tue Nov 27, 2018 5:58 pm
Here’s the machine...Image
Machine has a negative ~16-20” compound radius which gets transferred as a positive to the FB
Neck is attached with the flat, untouched FB. Make witness lines...
Place on machine...Image
Check and course correct as you go...
Feather the edges of the last little u-shaped area and Roberto is your Uncle.
This can also sort out any anomalies in shape at the body join and deviations in the joint between the fb and neck. I use a 2 way rod and snug it backwards before profiling.
Joyous results.
The machine most definitely requires a ‘knack’, without which a great deal of sadness can happen real quick...:)
Not that I’d know!
PostPosted: Wed Nov 28, 2018 12:15 am
Thar she sits! Thanks for sharing Ed. Do you sand any Fall Away in before or after? Or just go totally straight?
PostPosted: Wed Nov 28, 2018 12:41 am
The third picture from bottom with the u shape shows the fallaway, where the straight plane of the machine template doesn't actually touch the FB.
I guess technically the fallaway is built into my geometry.
